Interference check - select element from list
In the interference Report list you can only use the show button to highlight an element, but in a 3D view there could be thousands of elements making it sometimes impossible to see. Add a select button to the list for the clashing element that is housed in the model. This will help to orbit around in 3D and also lets you use the selection box tool to crop the view around the selection for a quick run through of new clashes.
