MEP Fabrication Parts - When placing the part from the correct pattern, automatically change to the matching serice
It seems to be common that Supply / Return are two Services built from the same Pattern. In some cases, we'll use multiple services which are very similar, but separated by letter designations. In Revit, if you try and place the correct ITM from the incorrect Service, you get the error dialog below. It would be helpful if Revit noticed that the target part is from the same Pattern as the placed part and offer to change the placed part service to match the target part. When building parallel supply and returns, it would be nice to not constantly switch the service, or have a way for this error to self-resolve.  I would consider making it the default option.
