Could the BIM360 description be added to the Revit BIM360 UI?
we work with many files that use a document control number for the file name, but then a description of the actual file information.  That being said, it is difficult learning document control codes to know what file needs to be opened and or linked.  I noticed someone post the same idea for Civil 3D (HERE) so I'm guessing this would benefit all platforms.
Comentarios
I would have thought this would be a simple code upgrade, and something that should not be missing from the UI, Hopefully AutoDESK will add into an update in the very near future. :cara_que_sonríe_con_ojos_sonrientes:
We have similar coding for models but still people who is new to the project would be not familiar with the codes and confused. It would be much better if we could have the descriptions to make things easier. Otherwise what's the point of having the descriptions only on the website version but not in Revit itself?
