Raster Printing - Change embedded JPG images to PNG format
Nobody likes raster printing, even at "presentation" settings.  It looks awful.  The embedded JPG has a 30% quality setting, tops.
There are many threads on Revit Ideas about "make Revit print vector in X situation."  These are great ideas!  But, in the meantime, could Revit switch to a higher-quality embedded raster image?  Maybe using the PNG file format instead of JPG?
(EDIT:  If I try to export my entire 24x36 sheet as a 600 DPI PNG image to work around the above issue, Revit actually exports a JPG image and then converts it to a PNG?  There's something deeply wrong with rasterization in Revit, and I can't fully wrap my head around it.)
