change family parameters in group leads to ungrouping
Changing the family parameter which exist in more than one group. Lead to ungroup the group
Comentarios
@Menna_salama ,
Thank you for your Idea! Just to clarify, is this an issue you are currently having, or is this something you think should happen when you change a family parameter? It sounds like it could be a bug that you're experiencing, if I am reading this correctly?
-Kimberly
