Shift + Select for Dynamo Scripts vs bounding box only
The Dynamo script that allows for the user to select objects in Revit won't allow for a shift+click method of selecting multiple objects.  Super annoying.  Only work around is to create a view with only those objects in the view and create a bounding box.  This might work fine in software testing but in day to day practice, it takes more time to do the work around than what the dynamo script probably saved you in time.
