Revit doesn't always remember offset
Hi all, when i create a detail item and set an offset, when i try to create a second one then Revit doesn't remember my offset and i need to type it every time, this is very time consuming when there are many eg. wall elevations or views that you need the same offset, can you make Revit to remember the offset value or add an option to remember that please?
