KEYNOTES fix update
Would be ideal if you can add a more fields to control the number order of keynotes..
example..
1. txt
2. note
3. line
but needed to change note 3 and make it 1!
currently you only have two fields available Key value & Keynote text.
need to add keynote number.. to be able to over write the default.
we can do this on schedules for the Sheet Index.. to place sheets in the correct Order..
hope this will be helpful to all Revit users.. Cheers
