Callout and Section views - default display for intersecting views
It would be greatly helpful if uses had better control of the default display for intersecting views for callouts and sections.  Currently the default for callout views is "Parent Only".  Section views, by default, are not visible in views coarser than the parent view.
The section view setting is usually the right choice but there are times when it is not.  Callouts default of Parent View only, I find myself changing this most of the time.  There needs to be the ability to adjust and manage these defaults with a setting and/or view template.
Please give us the opportunity to manage these settings on the fly and in project templates.
thanks,
Ian
