Automatic selection of values for all parameter in Revit filter drop-down list
I would like to introduce the idea of enabling automatic value selection for all parameters from the Filter Rules drop-down list in Revit.
Currently, it is possible to automatically select from the drop-down list mainly hard-coded or predefined parameter values, such as Discipline or Phase.
When selecting other parameters, e.g. custom defined parameters, the list is empty and it is necessary to enter the values manually.
With the new functionality, it would be possible to select from a drop-down list all previously entered values for each parameter, for example by custom project parameters, such as Project Browser Organisation parameter values. This would speed up filter creation and avoid the possibility of a mistake or typo.
