Project Parameter Properties Dialog - "Hide un-checked categories" should be default checked.
On the Project Parameter Properties dialog window when reviewing a project parameter, in order to easily see what categories this parameter is assigned to, we have to check the "Hide unchecked categories" button.  I think this should be the default state or should be settable as the default in options or at least in the revit.ini.
Please make "Hide unchecked categories" the default option anywhere this option occurs.
Comentarios
I see where you are coming from.  I would propose to not Hide the unchecked categories by default, but improve the category list organization by grouping all the checked categories on top (A to Z), a break line, then all unchecked categories below it (A to Z).
@ToanDN, I like that idea.  That would require a bit more work on Autodesk's part than just changing the default, but it would definitely be nice to be able to see both the checked and unchecked, but list the checked one's first.  Great addition to this idea.... that you didn't seem to vote for??
@Ric_Weber Excelente ideia! obrigado pelo envio
