Electrical homerun arrows
Can you create a secondary homerun in Revit that has a different homerun leader, like a continuation, circle, or filled circle? This way someone can switch out the current wiring homerun to another option. Sometimes I have the need to showing things as going up, down or continuation to another place. Right now, I have arrows with a keyed note or just a note telling them where to look for the continuation of that circuit. I feel this would make things simpler to understand the circuiting and cleaner looking for the drawings. My other option is adding a to the circuit tag a designation (TIE) when I place the circuit number at the end of the homerun. ie. P1-12 (TIE) which is basically using the E-tag with panel name, number and comment on same line.
