Move Text With Parameter
The ability to Move Text with a parameter
In First screen shot annotation on all sides are fine. In Second screenshot the object was made bigger. The annotation is now inside object when should be outside as screenshot 1. This would aid in quickly inputting standard annotation on and element where various sizes are used throughout the project. By being able to specify annotation position in relation to geometry it can quickly be inserted with all required dimensioning and text notes required, and able to be reused with all this annotation throughout project and other projects if required.
