About line width
My English is bad ,please ....
能不能允许在构件编辑界面设置线宽?
我需要把模型做得足够精细,如果不能方便的控制线宽,当很多细线相邻的时候就会出现很多粗线,手动一条条的去修改线宽会太麻烦,而且某些墙体转角地方还不能被修改线宽。
如果能在构件编辑器里面就能对材料在剖面图中显示的线宽预先进行编辑,那就不用再去各个视图中修改线宽了。
Comentarios
straight from Google Translate:
"Can I set the line width in the component editing interface? I need to make the model fine enough, if you can not easily control the line width, when a lot of fine lines adjacent to the time there will be a lot of thick lines, a manual section to modify the line width will be too much trouble, and some wall angle Place can not be modified line width. If you can edit the width of the material displayed in the section view in the component editor, you do not have to change the lineweight in each "
Have you tried using "Override Host Layers" in the "Visibility/Graphics Overrides" dialog? [您是否在“可见性/图形覆盖”对话框中尝试使用“覆盖主机图层”?]
Possibly a related idea:
https://forums.autodesk.com/t5/revit-ideas/overriding-visibility-graphics-by-host-layers/idc-p/70880...
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
