Detail Component nested in Mullion Profile family
Can we please have a little bit of consistency with the behavior of nested detail components in families.
At the moment if you nest a detail component into most families, the detail items are available to snap to with dimensions, detail lines etc. This is what we would expect, however, when detail components are nested into profiles, to create mullions, the detail component shows in the resulting mullion but the detail item geometry is not snapable. This makes it quite difficult to create window assembly details (see attached image). A work around is to place the detail item aligned and locked over the mullion in the detail then dimension to this.
Comentarios
