Rename text on tables (in columns by Query like fourmula)
Some times, when you have big project with lots of Parking Lots or Grid Liness, renaming them after a sustantial change (or even a little change) on the project it's time consuming activity, but it is not productive activity, and could be eliminated by automating Revit a little more.
In AutoCAD we have a great command, TCOUNT (Text Count) that let you rename text in your project based on it geometrical position. Will be awesome to have a tool like this on revit to renaming components in the models.
But also will be great improvement (I think a mandatory one) to implement a Query Calculation Tool, or similar, that let's you calculare and RECALCULATE or RENAME by formulas the fields on table columns. It should allow you to rename fields with texts and / or numbers in descending or ascending order (1, 2, 3, ...; a, b, c, ..., a1, a2, a3, ...), and if possible, by orden based on their geometric position (if you do the query in geometric objects).
Comentarios
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
