Correct Wall wrapping and partial void error
When a family with a partial void (such as for a wall niche or recessed equipment) cuts the wall, and that void passes the center line, and another element or the wall itself have wrapping turned on the appearance of the layers breaks and the outermost layer enlarges to the centerline or defined wrapping depth.  This graphical error is apparent in 2d and 3d views that cut the void.
Please correct this error so that partial voids of any depth can be used to cut walls.
Comentarios
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
It would be nice if Autodesk would fix this wall layer wrapping bug before finishing wall features and moving on to new features.
I do not see it documented but this looks to be fixed in Revit 2023.
I don't know about Revit 2023, but still a problem for Revit 2022.  A bug like this should not be subject to a "vote" and ignored for seven years, it should just be fixed as soon as possible.
