Improve API access to the Ribbon function (Explode Imported DXF/DWG)
I would like to have access to the functions available in the ribbon when an element is selected.
Help | Explode Imported Geometry | Autodesk
No commands related to exploding a DWG or CAD is available in the PostableCommand Enumeration and thus I cannot use the LookupPostableCommandId
A similar topic has already been posted here but it is archived.
https://forums.autodesk.com/t5/revit-api-forum/explode-dwg-api-postablecommand/m-p/10983570#M61956
Thank you for voting for this topic, do not hesitate to add elements!
Comentarios
