IFC Import
It would be nice to filter IFC elements while importing with a filtre that can use and read the IFC parameters such as IFCName, IFCType and so on (you can pick what you want like in an open bar).
ex. I want to import a model from an architectural practice, normally thay have a huge mess inside (they've designed also the place for the dog and the bonsai on the table, sooo cool but not really the aim of my job), I'd like to recognize the structural elements like walls or floors etc using a category filter while importing.
Is it such a problem?
Comentarios
I hope some sort of selective ifc import would be great.
While it is far from user friendly, you can already setup the importer to ignore certain ifc classes and set them to <not imported> inside your ifc import options.
