Masses and surface module
The masses and surface module allows you to calculate the gross floor area, but there is no option to see the surface in the ground plan. It would be great to see the whole surface which is the gross floor area. There needs to be some way to see in detail which surface was used for the calculation. The floor plan should be based on a color key, for the needed possibility to compare different parts. That would be a useful update for the tool.
