In the current situation, Revit & Plant 3D work as different entities. We cannot integrity design directly (As possible with AutoCAD MEP fabrication & Recent development in Revit for Smart P&ID integration)
Please raise the idea and give us the possibilities with this new advancement.
Option 1
- Revit can build a design model of Piping
- For detailed design, Revit Piping can be inserted in AutoCAD plant 3D. where user can assign Piping spec., hangers and Isometric drawings
Option 2
- Design model developed in Revit
- And Fabrication part feature has the option to adopt the AutoCAD plant 3D component library.
- After the building up fabrication model. Autodesk provides advance add-ins to export PCF files for Isometric.
