I am not talking about the lines which display the height but the contour of the toposurface itself (the edges) and when having a pad the lines created by the pad. And also lines created by subregions. Subregions create 2 contours, those of the region itself and within the toposurface there are other lines. So by overriding the subregion you face the problem of having a another Line by the toposurface itself that can't be overridden at all.
It is impossible to override any lines with the line override tool.
