Allow to cut walls, that are outside of groups, by voids that belong to windows within groups.
On behalf of a customer from Germany let me submit the following request:
This currently works only if just one instance of the group is place. After the following warning it is possible to cut the wall: "A group has been changed outside group edit mode. The change is being allowed because there is only one instance"
But if more instances of the group are placed a different warning appears and the cut geometry between the wall and window won't executed unless the group is edited/ ungrouped.
ps- Similar restrictions seems to have API/ Dynamo as well> through Dynamo script is is allowed to cut just by one instance of the group, but not by more.
