"Height Offset From Level" parameter for In-Place Ceilings
When modeling an in-place component and then setting the type to "ceiling", the resulting object has a parameter called "Elevation From Level". Meanwhile, all other ceilings have a parameter called "Height Offset From Level". Therefore, when tagging an in-place ceiling, a unique tag must be created, as well as a new shared parameter. I think an in-place ceiling should have the same height parameter as a typical ceiling so it can be tagged normally.
