APPLY schedule properties without closing the dialog
when you are working with the schedule properties, from the dialog, you need to close it to check the result of your settings.  It would be great to skip this step, and be able to check the schedule setup as many times as needed before accepting.  The same as all other Revit dialogs, that's it
so simple
APPLY schedules properties without closing the dialog
