Wall Location Lines
It would be great if you could set the location line along any layer of the wall. In my projects I would have the same location line in each wall type in all situations that I can think of, or else I'd have another wall type which could have a different location line if needed. There are a lot of companies that utilize multiple walls to create an assembly so they can achieve the desired behavior of each "layer" which often creates more work in the end, and more steps = more errors. With more control in assemblies like this and my other idea for Wall Visibility Settings by layer, this wouldn't be necessary at all.
Perhaps the location line can be defined in the assembly page - when set you could no longer define by instance - or perhaps defining by instance overwrites the setting in the assembly.
Thanks for reading
Cheers
