Preserve Room Tag Orientation While Mirroring
When mirroring a project, the room tag orientation is changed to "Model" instead of Horizontal or Vertical. When mirroring North to South, the Model orientation flips the tag so that the top line of the room tag is now the bottom line of information. Users then have to manually switch the room tags back to the original orientation. Preserving the Horizontal or Vertical orientation of the room tag would save users time, so that the room tags do not need to be adjusted after mirroring.
