AutoCAD has this dragmode variable which let you specify if you can see an object while moving / copying / rotating etc. it. Revit does something similar when you click and hold an element and then move it around; it shows an outline of the element. But when you select an element and then click Copy / Move etc. it only shows a rectangle, not an outline of the element. I would like to see an element's outline for all those modify commands?
