Void element
Void should be a seperate element in MEP such as pipe and ducts. MagiCAD is now used to create voids wich are used to coordinate with construction, but this is not a good solution as the element is either a generic item or a mechanical item. It should have its own category. This would help both with coordination, view layers and tagging.
