in filter creation mode:
instead of manually having to select each category and figure out if the parameter is applied or not to a category, it would be much more efficient, from an end user point of view, to be able to select the parameter from a consolidated list of all the parameter, then get the categories automatically ticked/picked, and then being able to remove some of them if necessary.
- filter creation
- select parameter from list of all the parameters
- remove categories if necessary
- (then pick another parameter and so on)
