curtain walls - imposts and panels according to the described curved shape
Hello. Offer for stained glass windows. When performing stained glass glazing of a skyscraper on curved shapes, the impost and glass remain geometrically rigid elements. If you perform segmentation (No. 1) along a circle, this section is divided into smaller sections so that a circle appears approximately In all this there is a minus of modeling and it loads the system very terribly. For this solution, we had to go to a trick - the glazing panels were replaced with walls. And impost on the protruding profile and manually adjust their positions along the horizontal plane. The problems with the curvilinearity and loading of the project have been solved, but it is still a more resource-intensive task and in fact these elements are not adapted to the type where they do not belong. Since the next stage will be the specification of elements and you will have to have fun with filters. A more optimized solution is required for stained glass windows with their curvilinearity and the described shapes, since the most recent solutions are already on the market.
