New Category & Button For Steel - "Components"
The add components such as a tread for a structural steel staircase. This would fall under a category "Structural Components".
The button would work in same way as it does on the architectural tab whereby clicking on it shows you a list of components that you could add to your structural steel model which don't fall under the existing buttons.
related: https://forums.autodesk.com/t5/revit-ideas/structural-stairs-and-railings-families/idi-p/7344239
