Enable switch to activate the cut for structural columns in RCP view depth
Currently, the structural columns placed in view depth for Reflected Ceiling Plans will be not cut, but the whole geometry will be displayed. This functionality may be confusing when the column is joined with other elements and includes some additional edges, that are displayed.
Here an example: the view depth reaches up to 30cm above the level, only the lower part of the column is included within the view depth:
The column is joined with two beams at the top:
In RCP the top edges, where the column is joined with beam are displayed, as the cut in view depth doesn't apply to structural columns.
The possibility to choose if the columns should be cut within view depth would be helpful to avoid confusion about which edges are in the view depth range. Especially if there are also elements that are cut in view range in the same view.
