Linking Projects in BIM360
Issue: [Shown at (1)] When linking a project file from the BIM 360 Hub, the default path is the project hub root.
Idea: [Shown at (2)] When linking a project from the BIM 360 Hub the search folder is the LAST folder selected in the same was as localised versions on Revit, AutoCAD...
