Filter type in properties selection
the ability to filter types available in pull down to select types. This is OK if you have a few items (generic models, levels, sections, wall types....) but if you have allot of a given items it would be handy to have a window whereby you could perhaps tick/untick a box of the types available that would show in the properties pull down OR a button whereby you could type some text and filter only items containing that text etc... This would be different from the search feature which is currently available when you click the drop down to select a type and you can type to filter, as you might know the name of the type off hand.
Comentarios
