Automatic Ceiling tool should recognize columns
I searched if someone else posted this already. I found threads all the way back to 2010 about this problem. The automatic ceiling placement tool only recognizes walls, but no columns. the only workaround seems to be to draw the ceiling manually, or to build a wall around the columns.
Some people reported Structural vs. architectural columns makes a difference. But IME they both don't work with the tool.
Assuming future buildings also will use columns, please let the automatic ceiling placement tool recognize columns
