Drone View
I would like a drone video. You could pick points in a random path around the project. Each point you pick would have an elevation and a camera angle. It would draw a path between points and the path could be selected and you could set speed (Speed up on some paths and slow down on others). As it moves from point to point along the path camera pans it's view from the aiming point on point #x to the aiming point on point #y.
Comentarios
