Parameter visibility through formula (conditions)
It would be cool to make a parameter visible based on certain conditions (with a formula?). In that way the end user of a Revit family, for example, sees a yes/no parameter based on formula driven conditions through a formula.
The problem we're now facing (for example) is we have a yes/no condition, whicih is applicable for a product within 2 diameters (out of for example 10 diameters). You could inform the end user about that through the tooltip, but make the yes/no visible only at those parameters would be extremely cool and useful.
Comentarios
Yes that makes perfect sense.
Also if you have different types it can often mean different information to set. If you had a part made up of a round tube you would be setting diameter whilst if it is a rectangular tube you would set two length parameters. You don't want to see parameters that make no sense to the object still visible.
