A friend found this strange behavior on the Schedule Panel when using Switch Phases on Revit 2021 and 2022.
When you switch phases on an electrical circuit with 2 hot wires and the circuit has a balanced load, for some reason,
Revit unbalance the load circuit and consequently add a Neutral wire even if the Wire Type has Neutral Required disabled.
This just happens on the phases AC and BC, if the circuit is on the phases AB works like should be.
I hope this helps to improve the next version of Revit.
Related Links:
