The color controlled option about export multiple categories to same DWG layer in Revit
When exporting DWG from Revit, with the export option that all pipes and fittings are the same layer and export Color as "Export category properties BYLAYER and overrides BYENTITY "&"Specified in view (True Color - RGB values)", then the layer color of exported DWG is controlled by the first element in multiple categories that have different colors are set to be exported on the same layer. Please add an option to choose which category color should be used but not the first one.
Comentarios
Hopefully the exported layer could be more flexible to setup one day,
instead of using by entity or category-modifier to add the suffix,
we're be able to change the whole name like by family-type or by comments, or even by color.
