Model Groups - Edit Attached Detail Groups from within Model Groups
Please allow updating Attached Detail Groups from within Model groups.
It is an inefficient workflow to not be able to edit a duct/pipe within a model group owing to a size tag that gets edited (eg. trim 2 ducts together with one already tagged). The dreaded "cannot edit outside of the group editor" error appears, requiring one to finish editing the model group, edit the detail group, delete the tags, finish and edit the model group, redo the required update, finish editing the model group and then re-tag.
At this point, the most time-efficient workflow is to just delete the tags before editing the model group, but I don't believe this to the intended design? Surely there is a better way.
