Make RESET available in Visibility/Graphic Overrides window
Hi;
In some cases, specially in elementary level of using REVIT and while someone  is changing  Visibility/Graphic Overrides window settings and check marks of visibility, it will be needed to RESET the setting to its default values and visibility check mark the same as the related discipline of the REVIT file.
As I explained above, it would be so useful if AUTODESK add an option to RESET settings  of Visibility/Graphic Overrides window.
Thanks in advanced
