Make it posible to import geometry from gbXml files just exported out of Revit or from other software
Currently it´s not possible to import geometry from gbXml file into revit unless you first processed by an external analysis software. When I try to import a gbXML I get the message "The XML file does not contain any Result elements.
The support has evaluated the problem. (CaseNo:17899119.)
Comentarios
Thank you for adding the support ticket, @Christoffer.Brand !
-Kimberly
Autodesk Support
Autodesk Support
Thank you @Christoffer.Brand for posting this idea. Additionally I refer to the article I created describing the current workaround: "The XML file does not contain any Results elements!" when opening gbXML in Revit.
