TPS Project Information - Doesn't empty parameters that only exist in the destination file.
Current situation: Transfer Project Standards of Project Information empties values of parameters that only exist in destination file.
Per Dev Team "This occurs because the project info is essentially treated like a single large element; parameters and values can be transferred but if a parameters doesn't exist in the document you are copying from, Revit doesn't have a match and the value will be cleared. This is how TPS has always functioned in regards to project information parameters."
Improvement Request: TPS of Project Information only affects parameters/values in the destination that exist in the source. Or better yet, choices on what to do with each; common, only in source, and only in destination.
Use Case: As building engineers we would like to include our own in-house project information as shared parameters (internal project name & #, etc). These differ from the standard project information, which are used in the project’s title blocks as determined by our clients (architects). TPS of Project Information is efficient in bringing over the information but erases “only in destination” information causing rework.
