Modeling ceilings
I work for a firm that does a lot of facilities with large vaulted lobbies.  Many of these areas have multiple slopes or angles in the room.  My suggestion is to add a feature where you can have multiple slopes in a single ceiling so that it is seamless, just like a roof.  I also think that the feature of being able to use the full version to manipulate individual points within the ceiling so that you can make it a variable structure would also help.  This comes to play in areas with coffered ceilings or again spaces that have multiple slopes going to possibly a higher elevation of a flat ceiling in the same space.
Comentarios
Currently Ceilings can only have a single slope assigned. Add the ability to create two or more slopes for sloped ceiling conditions.
Thank you for your submission, @PeteHill7315 ! We combined your Idea with a similar Idea!
-Kimberly
It will be great if ceilling have the same subelements (like floor), but also be able to have more than one slope definig edge (like roof).
