Keyboard Short cuts - Attached to profile
It would be wonderful if my keyboard short cuts would follow to a new machine / new version of revit / autocad via my login profile.
Comentarios
I'd like to expand on this request, just have all autodesk settings (each product) be saved to your cloud account. That way every year i dont have to go back and redo all my revit settings in addition to shortcuts.
Keyboard Shortcuts along with several other configuration files are stored in your
%appdata%\Roaming\Autodesk\Revit\Autodesk Revit 2020
folder and can be copied between machines and often even between versions
they did this in autocad, they should be able to do it in revit
