Make measure (ruler tool) more visible
When using the ruler (measure) tool the result is sometimes difficult to read if it is over another object. It would be nice for it to have a white-out behind like dimensions do to make sure it is always visible.
Comentarios
Here is a screencast of the issue: https://autode.sk/3dwWfPu
You can see the total length of the measurement also on the top-left of your screen:
But still it would be nice if the same value, shown at the place where you are measuring, should be better visible.
