Section boxes have a top and bottom. It'd be great to have that tied to a level so that 3D views can be setup with precision. And exporting Level slices to Navisworks is a lot easier.
It would be very useful if these were in the properties window! Especially since its so hard o locate the arrows, and at certain angles top and bottom ones are grabbed by mistake.
11-12-201606:28 AM
11-12-201606:28 AM
This can be done by clicking right on the viewcube and select orient to ...
@Anonymous That's a tolerable work around for level slices, and for views you set up once for a sheet, but for general use it's annoying. I'd like to be able to select the section box and, without changing my view, adjust what I'm seeing. For example, I might start with a view that's showing the first floor, and want to see the entire building. Ideally I could select the selection box and change the range to 40'. Instead I have to twist the view to find the arrow, then eyeball how much to drag it (usually taking 2-4 times) to see what I want, then twist the view back to approximately where I had it.
