Steel Connection Contour Cut new ideas
Hi, I think the Steel connection contour cut has space to grow to show and schedule then beam penetrations. Below are some ideas.
  • create a new category for Beam penetrations for easy schedule and filter
  • the new category will have type elements to manage similar penetrations
  • have the option to add a symbol element to show where the penetration is located on the plan.
  • Have the capability to use the new category for coordination.
  • a new tool to create type penetrations based on the interference check or the navisworks report conflicts with Mechanical ducts or pipes ( no a dynamo script)
I think there is more to grow, but it is a good start point
