Make text offset right for Linear Dimension Styles
In dimension styles the text seems to be positioned too far from the dimension line. So, i set the text offset to 0,5 mm, then i do a measurement from the line to the text font and Revit shows 6,5 mm. That means the 0,5 mm text offset is measured from the text background border, not from the text font. I can find no option to set the offset from the actual text font.
In Autocad, the text offset is measured from the dimension line to the text font, regardless of the text background. Therefore, a text offset of 0,5 mm IS 0,5 mm indeed, not 6,5 mm as in Revit.
Please keep consistency with Autocad, meaning:
- fields have opaque background by default
- dimension text have transparent background by default
- text offset is measured from text font, NOT from text background
